Disable automount
gianluweb
Wed Oct 20, 2010 10:13 am
When automount is checked and drive is mounted there's not a way to uncheck the flag (is grayed), so at every reboot the drive is mounted and the only way is to force dismount (cutting all open handle?).
There's another way?
thanks
bye
Gianluca
Mon Oct 25, 2010 9:18 pm
Edit registry I guess. But again, are you using StarPort or StarWind iSCSI initiator?
gianluweb
Tue Oct 26, 2010 11:35 am
There's no problem to modiy the registry, but i can't find the right key, can you help me?
I'm using starwind iscsi initiator 5.5.
thanks
Max (staff)
Thu Oct 28, 2010 9:20 am
The best workaround is to turn the drive offline, disconnect it and connect back with automount disabled.
Max Kolomyeytsev
