Two problems with StarWind 3.5.1 on W2k8 RC1
DMashkov
Fri Dec 21, 2007 9:10 am
Hello!
I am testing StarWind 3.5.1 on W2k8 RC1. Two problems appeared:
1. If I try to log in with username "test", but without password, StarWind console shows an error, and then an endless "Please wait" progress bar that never stops. If I click Cancel in it, I get:
StarWind
This will drop the connection, you will need restore it manually. Do you really want to stop the operation?
Yes No
If you are interested, I captured process's hang dump.
2. I created a RAM disk, and connected it to another W2k8 RC1 server. The disk appears correctly, but fail to format. At this time, Microsoft iSCSI Initiator logs following errors:
Log Name: System
Source: iScsiPrt
Date: 21.12.2007 12:48:50
Event ID: 7
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: heron1e12.CO.SOK.RU
Description:
The initiator could not send an iSCSI PDU. Error status is given in the dump data.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="iScsiPrt" />
<EventID Qualifiers="49152">7</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2007-12-21T08:48:50.028Z" />
<EventRecordID>18903</EventRecordID>
<Channel>System</Channel>
<Computer>heron1e12.CO.SOK.RU</Computer>
<Security />
</System>
<EventData>
<Data>\Device\RaidPort0</Data>
<Binary>000090000100000000000000070000C00000000000000000000000000000000000000000000000000D0200C0690071006E002E0032003000300033002D00300036002E0063006F006D002E0072006F0063006B00650074006400690076006900730069006F006E002E007300740061007200770069006E0064002E006800650072006D006500730032006500310032002E0063006F002E0073006F006B002E00720075002E00720061006D00640072006900760065003000</Binary>
</EventData>
</Event>
Log Name: System
Source: iScsiPrt
Event ID: 49
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Target failed to respond in time to a Task Management request.
Event Xml:
<System>
<EventID Qualifiers="49152">49</EventID>
<Level>2</Level>
<Task>0</Task>
<EventRecordID>18905</EventRecordID>
<Security />
</System>
<EventData>
<Binary>000001000100000000000000310000C000000000000000000000000000000000000000000000000007</Binary>
</EventData>
</Event>
Log Name: System
Source: iScsiPrt
Date: 21.12.2007 12:49:09
Event ID: 34
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Description:
A connection to the target was lost, but Initiator successfully reconnected to the target. Dump data contains the target name.
Event Xml:
<System>
<EventID Qualifiers="16384">34</EventID>
<Level>4</Level>
<Task>0</Task>
<TimeCreated SystemTime="2007-12-21T08:49:09.433Z" />
<EventRecordID>18913</EventRecordID>
<Security />
</System>
<EventData>
<Binary>00008C00010000000000000022000040000000000000000000000000000000000000000000000000690071006E002E0032003000300033002D00300036002E0063006F006D002E0072006F0063006B00650074006400690076006900730069006F006E002E007300740061007200770069006E0064002E006800650072006D006500730032006500310032002E0063006F002E0073006F006B002E00720075002E00720061006D00640072006900760065003000</Binary>
</EventData>
</Event>
Bohdan (staff)
Mon Dec 24, 2007 11:12 am
Hi.
Thank you very mush for the valuable information.
I confirm that the problem #1 really exists and will be fixed ASAP.
As for the second one - could you please send us logs from StarWind installation directory to investigate what's wrong.
jblaine
Tue Feb 19, 2008 12:59 pm
Just FYI, this happens in Vista (Ultimate) as well.
Tue Feb 19, 2008 7:59 pm
1) What version are you using?
2) Where's your StarWind log?
