iSCSI on Linux
mastachef
Mon Jul 28, 2008 11:58 am
I have an ImageFile on a physica partition (Windows Server 2003). I have setup, I believe, RHEL 4 with iSCSI support and I am able to connect to the ImageFile. Now, my next task is to be able to manipulate the file from the Linux client.
My question is how does one connect to the ImageFile? What should I be looking at as far as the process of mounting on the Linux side? Any help would be appreciated. Thanks.
Mon Jul 28, 2008 6:21 pm
You're connecting to iSCSI target. What does it do to virtualize at the low end it's really it's own problem. So for you it's an emulated hard disk.
mastachef wrote:I have an ImageFile on a physica partition (Windows Server 2003). I have setup, I believe, RHEL 4 with iSCSI support and I am able to connect to the ImageFile. Now, my next task is to be able to manipulate the file from the Linux client.
mastachef
Tue Jul 29, 2008 5:16 pm
Anton, thanks very much. I was able to get it working with Bohdan's help (and notes). Keep up the good work you guys.
Tue Jul 29, 2008 7:52 pm
Thank you very much for keeping us updated! We'll release Linux initiator HOWTO manual with the next major StarBurn update. FYI. Thank you!
mastachef wrote:Anton, thanks very much. I was able to get it working with Bohdan's help (and notes). Keep up the good work you guys.
mastachef
Thu Aug 14, 2008 3:39 pm
I meant to ask this a bit ago. For Linux (RHEL4), the /etc/initiatorname.iscsi file can be edited for a target name. Is it possible to add more than one target name in this file and what would be the syntax?
Thu Aug 14, 2008 5:14 pm
We're busy enough with our own software. So please bug Red Hat with this question :)
mastachef wrote:I meant to ask this a bit ago. For Linux (RHEL4), the /etc/initiatorname.iscsi file can be edited for a target name. Is it possible to add more than one target name in this file and what would be the syntax?
