I've found:
How the Cluster service reserves a disk and brings a disk online
http://support.microsoft.com/?scid=kb%3 ... &x=11&y=11
Each node in the cluster renews reservations for any LUNs it owns every three seconds. If the nodes of a cluster lose network communication with each other (for example, if there is no communication over the private or public network), the nodes begin a process known as arbitration to determine ownership of the quorum disk. The node that wins ownership of the quorum disk resources in total communication loss between cluster node will remain functional. Any nodes that cannot communicate and cannot maintain or acquire ownership of the quorum disk will terminate the cluster service and any resources that node was hosting will be moved to another node in the cluster.
1. The node that currently owns the quorum disk is the defending node. The defender assumes that it is defending against any cluster nodes that it cannot communicate with and for which it did not receive a shutdown notification. The defender continually renews its reservation to the quorum by requesting a SCSI reserve be placed on the LUN every three seconds.
2. All other nodes (nodes that do not own the quorum disk and cannot communicate with the node that owns the quorum resource) become challenging nodes.
3.
When the challenger detects the loss of all communications, it immediately requests a bus-wide SCSI reset to break any existing reservations.
4. Seven seconds after the SCSI reset requested, the challenger tries to reserve the quorum disk. If the defender node is online and functioning, it will have already reserved the quorum disk as it typically does every three seconds. The challenger detects that it cannot reserve the quorum, and terminates the cluster service. If the defender is not functioning properly, the challenger can successfully reserve the quorum disk. After ten seconds, the challenger brings the quorum online and takes ownership of all resources in the cluster. If the defending node loses ownership of the quorum device, then the cluster service on the defending node terminates immediately.
When a cluster node takes a disk resource offline, it requests that the SCSI reserve be released and then the drive will once again be unavailable to the operating system. Anytime a disk resource is offline in a cluster, the volume that the resource points to (the disk with the matching signature) will be inaccessible to the operating system on any of the cluster nodes.
