Eval with 1 client only?
vosen
Mon Nov 24, 2008 11:10 am
I followed the link that I got via email for downloading the eval copy of Starwind Professional. I want to test it for MSCS. When I try to connect the 2nd initiator I get a "Target Error" and the logfile has the following entry "11/24 11:39:30.203 c44 Srv: *LICENSE* Rejected iSCSI connection from 192.168.0.81:49195. Maximum of 1 allowed clients already connected to the server!". Is this limitation expected for the eval copy? Shouldn't it be full featured? Is it possible that I got the wrong pointer to the eval image?
Regards
Volker
Mon Nov 24, 2008 5:07 pm
You've applied FREE key. It does LOCK the version into one initiator mode. Simply unregister your StarWind and you'll have Pro functionality for evaluation.
samphi
Mon Dec 01, 2008 5:25 pm
hi,
i got the same problem but with a test of mpio (my first !! brrrr it's always hard the first time hein !!! ) , the second connection failed .
when i read the log i see at the begining :
licence data not found.
trial version
unlimited number of clients hosts allowed ( :D cool )
and after the second connection :
*limit* vm1 : all of 1 allowed sessions are opened!
in the licence registration dialog i have no licence .
whatever i tried to unregister , i restarted starwind and the limitation is still here .
:cry: snifff my bl460c is asking for more power !
thanks in advance for your help .
Mon Dec 01, 2008 10:18 pm
Same problem - same solution. Please unregister (send us registration information screen shot) and send us the log. So we'll point what you did wrong.
P.S. New version V4.0 will NOT have 1 connection limitation as we're a bit sick of it :)
Bohdan (staff)
Tue Dec 02, 2008 1:53 pm
Please create targets with "Allow multiple concurrent iSCSI connections (clustering)" option enable.
To ensure that a target may be used with cluster review its properties and make sure that it has "Clustered: Yes".
samphi
Tue Dec 02, 2008 5:38 pm
hi,
i confirm , i did the modification and everything is ok now !
mpio is now possible on my lab :D
thank you for your help !
Regards
Philippe
Tue Dec 02, 2008 9:09 pm
Good :) Thank you very much for keeping us updated :)
samphi wrote:hi,
Regards
Philippe
