I work for a small company who is looking to transition over to a VMware infrastructure. We're very tight on cash, and our IT consultants are pushing for a single equillogic 6100 for $30k, and I'm worried because we won't have HA with a secondary SAN. The equallogic would use twelve 1tb sata hard drives in raid-50, and they're expecting about 6000 IOPS. We have three types of virtualized servers running (sql database, exchange, and some low-load servers) with an estimated current use of 2000 IOPS.
I'm looking into the idea of building two SAN's and using starwind, and came up with two potential builds:
-=[ BUILD 1: Single Raid Volume ]=-
Case: SUPERMICRO CSE-846TQ-R900B Black 4U Rackmount Server Case w/ 900W Redundant Power Supply
Motherboard: SUPERMICRO MBD-X8DAH+-F-O Dual LGA 1366 Intel 5520 Extended ATX Dual Intel Xeon 5500
CPU: Intel E5520 Nehalem 2.26GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366
Heatsink: Intel BXSTS100A Active heat sink with fixed fan
RAM: Patriot PS312G13ER3K-E 12GB (3 x 4GB) 240-Pin DDR3 SDRAM ECC Registered DDR3 1333
RAID controller: Areca ARC-1680IX-24 24 Port PCIe x8 SAS RAID Card
NIC 1: Intel E10G41AT2 10 Gigabit AT2 Server Adapter - network adapter
NIC 2: Intel EXPI9402PT 10/ 100/ 1000Mbps PCI-Express PRO/1000 PT Dual Port Server Adapter 2 x RJ45
Hard Drives - OS: (2) Seagate ST380815AS 80GB 7200 RPM 8MB Cache SATA
Hard Drives - SAN: (12) Western Digital WD1001FALS 1TB 7200 RPM 32MB Cache SATA
-=[ BUILD 2: Two Raid Volumes ]=-
Case: SUPERMICRO 835TQ-R800B Black 3U Rackmount Server Case w/ 800W Redundant Power Supply
RAID controller 1: Areca ARC-1680IX-8 8 Port PCIe x8 SAS RAID Card
RAID controller 2: Areca ARC-1680IX-8 8 Port PCIe x8 SAS RAID Card
SAS HD Cages: Athena BP-SATA1842C 2.5" (SATA, SAS) Backplane Unit
OS HD Cage: iStarUSA BPU-2535V2 1 x 3.5" to 2 x 2.5" SATA I/II Hot-Swap Drive Cage
NIC 2: Intel: EXPI9402PT 10/ 100/ 1000Mbps PCI-Express PRO/1000 PT Dual Port Server Adapter 2 x RJ45
Hard Drives - OS: (2) Western Digital WD800BEVT 80GB 5400 RPM 8MB Cache 2.5" SATA
Hard Drives - SAS: (4) Seagate ST973452SS 73GB 15000 RPM 16MB Cache 2.5" SAS 6Gb/s
Hard Drives - ATA: (8) Western Digital WD1001FALS 1TB 7200 RPM 32MB Cache SATA
In short:
1. First potential build would have (12) 1tb sata drives, with the ability to scale to 24 drives. It would have 4 gigabit NIC's to run to the VM servers, and 1 10gb NIC to connect to the secondary SAN.
2. Second potential build would have (4) 73gb 15k SAS drives for SQL and exchange (scalable to 8 ), and (8) 1tb sata drives (not scalable) for all other VM's. Again, it would have 4 gigabit NIC's and 1 10gb NIC.
3. Each build is roughly $8k for each box, so $16k for a HA setup.
Couple questions:
1. What are the potential risks concerning building a SAN for use in a production environment? Is it worth the extra $14k to go with an equallogic (I know, loaded question)?
2. Do the builds look good? Any components have known compatibility or performance issues? Should I change anything (add 2nd CPU, more RAM, etc)?
3. Which build would give better performance? Does it make sense to break the use into a low spindle 15k RPM SAS and medium spindle 7.2k RPM SATA, or should we do a single high spindle 7.2k SATA?
4. What raid configurations would be the most appropriate? I would think raid-10 for the SAS drives, and raid-6 for the SATA drives. Does this make sense? What are the pros of using RAID-50?
5. How would these types of builds stack up performance wise (or otherwise) to an off the shelf approach like the equallogic 6000 series?
Thanks for the help, it's greatly appreciated
