Yeppers.Aitor_Ibarra wrote: Have you done all that?
Yes. There's 2 things you need to do.mooseracing wrote: Is there anyway to verify MPIO installed correctly? I remember enabling it and then having to reboot.
mooseracing wrote:So things have been going good since I update to 5.4 on both nodes, except on Monday and Last night I lost connect to my partner target.
I get these in the event log:
The initiator could not send an iSCSI PDU. Error status is given in the dump data.
Connection to the target was lost. The initiator will attempt to retry the connection.
Initiator failed to connect to the target. Target IP address and TCP Port number are given in dump data.
Then not even a second later reconnected.
It seems to drop out while the partner is running it's backups of our data. Is is feasible that the server is under 2 much of a load to respond to starwind?
mooseracing wrote:Well these are both direct connected, I replaced the cord. Guess I Will go from there and work my way up.
