HA ESX question
leiw324
Mon Nov 29, 2010 7:28 am
Hello
In the HA ESX document, the iscsi-initiator has two iscsi-target server IP address.
How can I know using which IP address to access storage ?
Thanks !
Max (staff)
Mon Nov 29, 2010 1:37 pm
When Using HA you acces the storage as a multipathed device, so the storage is available through both IP addreses. I would also recommend you to set the Round Robin MPIO policy for the datastore you create on the HA device.
Max Kolomyeytsev
leiw324
Tue Nov 30, 2010 1:12 am
Max (staff) wrote:When Using HA you acces the storage as a multipathed device, so the storage is available through both IP addreses. I would also recommend you to set the Round Robin MPIO policy for the datastore you create on the HA device.
Hello
1. If I do not setup Round Robin MPIO policy, is its still randomly access to LUN by two iscsi-target server IP address ?
2. Where can I find Round Robin MPIO policy manual ?
Thanks !
Constantin (staff)
Tue Nov 30, 2010 10:05 am
1. No it uses 1 path as active and second as reserve
2. Go to datastore properties, and choose option for managing pathes.
