Memory on WBcache
nycon1
Thu Dec 02, 2010 12:28 pm
How much memory I put on wbcahe for ha volumes?
Max (staff)
Thu Dec 02, 2010 4:54 pm
This depends on the storage size and purpose completley, can you provide some more information?
Max Kolomyeytsev
nycon1
Thu Dec 02, 2010 6:32 pm
3,8 TB RAID5
3 volumes with 1 TB
The purpose is VM´s (ESX4.1) storage.
6 MB of memory
Max (staff)
Thu Dec 02, 2010 8:08 pm
Since you are using a RAID5 which is not the best writer - I'd recommend to spend 2 Gb on cache
this will not be an overkill, however - as soon as you fill your cache be ready for write performance degradations.
nycon1 wrote:3,8 TB RAID5
3 volumes with 1 TB
6 MB of memory
Max Kolomyeytsev
