xenserver fails to reconnect after a failed node
idigital
Sun Feb 27, 2011 5:21 am
I have Starwind setup in HA and hooked up xenserver. All seems fine and when I turn off 1 node, the other one picks up. All good and well, until I turn the down node backup. Xenserver isn't reconnecting, I have to restart it manually in xenserver.
How do I get xenserver to auto reconnect?
Thanks for help!
Sun Feb 27, 2011 7:14 pm
Not sure did I got you correctly... Just to clarify. You have two node HA. Node A and node B. Node B goes AWOL and node A is still in service. When node B returns from AWOL Xen server continues to work with node A entirely. Is this correct?
idigital wrote:Hi,
Thanks for help!
idigital
Sun Feb 27, 2011 9:08 pm
Yes, it will only work from node A.
In xencenter I can see 4/8 paths only. but when I run command:
iscsiadm -m node session
It shows all 8 links active. But to restore all 8 paths in xencetner, I have to run connect manually:
iscsiadm --mode node --loginall=all
This will bring node B back into service
also, when I restart open-iscsi, it will logout but not log back in when it starts so I have to run login command again. Hope this little bit helps cause I know I am missing something reeeeallly simple...
Sun Feb 27, 2011 9:11 pm
What's inside StarWind log for Node B when it's recovered and in full sync with Node A (but still w/o active service for Xen)?
idigital
Sun Feb 27, 2011 9:27 pm
In Starwind, after the sync, only node A iqn's are there. The xen iqn is not showing up in node B, only node A
idigital
Sun Feb 27, 2011 9:35 pm
Also:
multipath -ll
shows those paths [failed][faulty]
Tue Mar 01, 2011 1:15 pm
Could you please provide more detailed information about your software configuration (version of Xen and StarWind)?
idigital
Sat Mar 05, 2011 6:06 am
Sure.
Xenserver 5.6 FP1 + Starwind 5.6
Is there an official step by step how-to guide or your latest one?
Max (staff)
Mon Mar 07, 2011 10:17 am
Hi, the official guide will be on our website soon, currently Citrix team and our Q&A are solving an iSCSI bug which prevents system from functioning properly. The solution should be available during this week.
Max Kolomyeytsev
idigital
Wed Mar 09, 2011 7:25 am
Ok great, please update us when it is out.
Wed Mar 09, 2011 3:50 pm
We'll keep you updated for sure. Thank you very much for your patience and cooperation!
idigital wrote:Ok great, please update us when it is out.
idigital
Sat Mar 26, 2011 3:40 am
Any luck on an official guide?
Sat Mar 26, 2011 8:49 pm
Closer to V5.7 release (mid-April 2011).
idigital wrote:Any luck on an official guide?
