Max, when I posted before saying that I was going to be using Citrix Xen Desktop with StarWind and asked if there were any problems with my proposed builds, you didn't say anything about it being problematic. We just brought our new data center up and spent a couple hundred thousand dollars on hardware and software but it isn't going to work correctly when I start the build next week? Or does it mean that I can't upgrade to FP1 yet?Max (staff) wrote:Well, then the only thing you can do is wait.
I will highly recommend to doublecheck the updates compatibility for future.
Running with Citrix XenServer can be problematic at some points.
That's a load off my mind. This is a new build that will be heavily tested before going into production next month.Max (staff) wrote:StarWind does work with 5.6 fp1 now, we have tested this in our labs, I was talking about doublechecking before updating the environment to avoid the situation of a long sync like in Idigital's case
rchisholm wrote:That's a load off my mind. This is a new build that will be heavily tested before going into production next month.Max (staff) wrote:StarWind does work with 5.6 fp1 now, we have tested this in our labs, I was talking about doublechecking before updating the environment to avoid the situation of a long sync like in Idigital's case
