cannot remove target?
brucifer
Wed Apr 20, 2011 8:34 pm
Hi, I am having an issue where I cannot remove a target. In the help I see a force removal
of target, but I do not see this as an option in the target menu.
If I just choose remove target, I get the message to confirm, and I do, and nothing happens.
thanks for any assistance
brucifer
@ziz (staff)
Thu Apr 21, 2011 7:34 am
brucifer wrote:Hi, I am having an issue where I cannot remove a target. In the help I see a force removal
brucifer
Check that the target is not connected to any clients (iSCSI initiators). You can see the sessions in StarWind management console when you choose the target iSCSI sessions.
You can also try to restart the console or reboot the server if previous suggestions won't help.
Aziz Keissi
Technical Engineer
brucifer
Thu Apr 21, 2011 4:46 pm
I have checked, no others connected, as well have restarted the console.
Was hoping to not have to restart. anything else i can try before i restart?
thanks
Max (staff)
Thu Apr 21, 2011 4:57 pm
Hi, what's the version you're running? I saw such behaviour in the old releases.
BTW: force removal should be available from the top right panel of the management console
Max Kolomyeytsev
