Switch Active Mirror
Aaron_Denton
Mon May 09, 2011 10:02 pm
I want to change which copy of my mirror is active. Can I just right click and select Switch Active Mirror?
I'm guessing I'll want to disconnect initiators beforehand?
Max (staff)
Tue May 10, 2011 3:10 pm
Hi, you can change the active mirror on the fly - it will not distrupt any data transfer.
However, note that the point of connection is anchored to the first mirror, the switch will reroute the data to travel primarily to the second mirror.
Max Kolomyeytsev
