elu
Mon Aug 29, 2011 12:58 pm
We are currently in the process of buying hardware on which we will probably use Starwind. We have the following on our list at this moment (2x for HA):
CSE-847E16-R1400LPB
X8DTi-LN4F
1x Xeon E5645 Six-Core
48GB ECC REG RAM
ADAPTEC MaxIQ 5805ZQ
17x SEAGATE Hard Drive 1TB SAS-600 7200RPM (1 hotspare)
1x OCZ Vertex 3 120GB SSD (read cache) (we might replace this with intel 320 SSD)
2 Ports X520-T2 Gigabit / 10 Gigabit
Using 2x Dell 8024 24x 10Gbit Base-T switches.
If you would recommend to change anything of the above, please let us know. One question we do have is if we should add 2 seperate disks for Windows/Starwind or if we could install this on a seperate volume on the RAID 10 array (which starts with 17 disks).
Mon Aug 29, 2011 1:47 pm
The configuration is good, as for me.
About your question: both options are good.
elu
Tue Aug 30, 2011 8:59 am
Thanks for the reply. 1Gbit sync channel will be good enough (crosscable best option?)? Both 10gbit ports will be in use to connect to two switches for redundancy and some extra speed.
Tue Aug 30, 2011 2:22 pm
That's extremely bad idea. Use 10 GbE to build a cross-link backbone and use 1 GbE uplinks for your clients.
elu wrote:Thanks for the reply. 1Gbit sync channel will be good enough (crosscable best option?)? Both 10gbit ports will be in use to connect to two switches for redundancy and some extra speed.
elu
Tue Aug 30, 2011 7:10 pm
Anton,
Could you send me an email (see profile)? We have 2x 10gbit switches and 2 10gbit ports per SAN available. Our idea was to connect both SANs to both switches. This results in 0 free 10gbit ports on the SANs.
Could we sync over the iscsi network? Of course we could connect 1 SAN to 1 switch, but i'd rather not lose a SAN when a switch goes down.
elu
Tue Aug 30, 2011 8:20 pm
Also, what kind of cable do you use to get a 10gbit crossover channel? I can't find any cat7 crossover cables, nor cat6a.
edit: it seems you don't need crossover cables with 10Gbit, but can simply use a straight cable. Could you confirm this?
Tue Aug 30, 2011 10:03 pm
I did. Asked for interconnection diagram as I'm a bit lost in what you're trying to achieve. Thanks!
elu wrote:Anton,
Tue Aug 30, 2011 10:04 pm
Absolutely! All modern NICs do pick up right Tx / Rx lane automagically.
elu wrote:Also, what kind of cable do you use to get a 10gbit crossover channel? I can't find any cat7 crossover cables, nor cat6a.
elu
Wed Aug 31, 2011 9:47 am
Anton,
I did not receive any mail. We have 2 switches and 2 SANs with 2x 10Gbit available. We were planning to connect every SAN to both switches, creating 4 paths. This way a switch can go down, but both SANs will still be reachable.
If we create a sync channel on 10Gbit, we will only have 1 10Gbit per SAN available. Then we can only connect every SAN to 1 switch, creating 2 paths. If 1 switch fails, 1 SAN will also be unreachable.
Wed Aug 31, 2011 10:37 am
Replied to both provided e-mails (gmail and corporate one) and brought you in touch with techies and sales
