Hi guys,
Over the last two days, I noticed that shutting down a Centos 5.7 server, connected to 8 iscsi devices powered by Starwind (two Starwind servers in HA, each exporting four disks via iscsi), during disconnection of iscsi, Starwind suddenly loses synchronization on one of the disks.
It is always the same disk, and this is being triggered by a brand new server recently setup. Actually, by two of them.
Now however, synchronization has been lost to such a point, that Starwind is rejecting iscsi connections on BOTH servers.
I see a lot of errors on the logs like this:
10/28 17:29:57.119 940 HA: CMSInitiatorDevice::SendCDB2Device: EXITing with failure, DeviceIoControl( IOCTL_SCSI_PASS_THROUGH_DIRECT ) failed, ERROR = 55, SCSI STAUTUS = 0!
10/28 17:29:57.119 940 HA: CMSInitiatorDevice::SendCustomControlScsiCommand: EXITing with failure, SendCDB2Device(...) failed!
10/28 17:30:09.271 564 PR: Set Unit attention 0x29/0x3 for session 0xe33 fr4om iqn.1994-05.com.redhat:8d501fc5f049,00023D010000.
10/28 17:45:21.358 920 HA: CSynchBarrier::EnterSynchBarrier: EXITing with failure, Max threads count(128) reached!
10/28 17:45:21.436 934 HA: CSynchBarrier::LeaveSynchBarrier: WARNING: Barrier block with p_ulptrBlockID 0x0000000476AFDCF0 is not found!
Theories? I have 100 virtual machines offline due to this at this moment.
Starwind version 5.7.1733.
