In a nutshell: we cannot complete nexenta tests as we put ZFS on knees. In a situation where StarWind can create 3TB data store using 4KB dedupe blocks (8GB RAM total, 6GB allocated for dedupe hash tables and 2GB used by system) nexenta cannot do even 20GB (YES, GIGABYTES).
You can read more on nexenta own forum here here:
http://www.nexentastor.org/boards/2/top ... ssage-5532
as they don't control ZFS and memory footprint is ZFS fundamental requirement I don't think they can do anything with it in the future.
You have hardware, you have access to both trials (and free versions, all of them include dedupe) so go run your face-to-face test run and publish and let us know IOPS, MBPS and dedupe final ratios. Othere people do it on the web comparing StarWind with MS target and FreeNAS (another ZFS based solution). Check this link (and corresponding 3 parts on the same blog). Here:
http://blogs.jakeandjessica.net/post/20 ... art-1.aspx
Good luck!
