Hello, we recently had a failed RAID 5 where the img file was located. after rebuilding the raid 5 and getting the img file of the hard drive, i tried to add it to starwind. that part worked fine, and had no issue. in vmware after rescanning for new storage devices and trying to add it i get the same screen i would get if the hard drive was blank with one difference:
Partion format "Unknown" The Hard disk is blank
I tried to repaire the file from the vmware console doing the following:
first i identify the drive:
fdisk -l
Disk /dev/disks/eui.f06d8f7d2432b633: 2097.1 GB, 2097152000000 bytes
255 heads, 63 sectors/track, 254964 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
then i try:
partedUtil fix /dev/disks/eui.f06d8f7d2432b633
Error: Unable to open /dev/disks/eui.f06d8f7d2432b633 - unrecognised disk label.
any ideas on a utility or a way to try to fix the file system inside the img? it doesn't matter if i have to extract the files from inside that in a different way and then load them again to another img file through vmware.
thank you in advance for any help you can provide.
Cesar
