Extend the size of HA iSCSI
Manos_Arriba
Thu Jun 07, 2012 8:46 am
I am using version 5.4 and I cannot seem to extend a HA iSCSI target. I have the option to extend a basic virtual disk but not for the HA version. Is there anything that I am doing wrong or can this not be done?
Manos
lodiver
Thu Jun 07, 2012 12:02 pm
AFAIK it cannot be done :)
at least with 5.4
Thu Jun 07, 2012 2:24 pm
lodiver wrote:AFAIK it cannot be done
at least with 5.4
Dear lodiver, BINGO :D
Manos_Arriba wrote:Hi,
Hello Manos_Arriba,
So, as lodiver mentioned it cannot be done with 5.4.
I will ask you to suggest you to install the latest version on your SAN boxes.
Please let me know if your SAN is in production environment for I to could provide you with the best upgrade instructions.
Thank you
Manos_Arriba
Thu Jun 07, 2012 2:29 pm
It is possible for me to break the HA and then add the image a local one to one of the servers, then extend, then remove that target and then recreate the HA again using the newly extended HA?
Not it is not in production. Is this functionality available in 5.8?
Manos
Fri Jun 08, 2012 9:39 am
Yeah, this would work, but as far as I can see from your next post ( http://www.starwindsoftware.com/forums/ ... f3c#p16072 ) you have already upgraded to the 5.8 so you dont need this workaround anymore :)
You should see the Extend Device option after you will right click on the device
