I am also curious if the current or new version would incorporate SMB 3 at all? So far, it works well and is simple to use
I understand I would need to attach local storage to the hyper-v boxes, that is not a problem.
sammybendover wrote:Thanks for the answer, I appreciate it. I have no problem running iSCSI, i have a 4 port intel nic dedicated for each host, so i get pretty decent throughput with iSCSI and MPIO
If you need any testing done for the beta version, let me know
sammybendover wrote:Is the native san included in the 5.9 beta?
sammybendover wrote:is there a beta available for for native san to support hyper-v 2012? I should of clairified my question, thanks!
