Change cachemod in starwind.cfg while running
sunyucong
Tue Aug 14, 2012 5:04 am
Apparently starwin read settings in config to everytime determine whether it should write back the cache memory , so if you initially have mode to wb, then change to wt and restart starwind, all your changes are going to be lost, which is not very safe I think.
Wed Aug 15, 2012 7:48 am
And you are 100% correct! To be honest it is good that you asked before doing something - it is strongly not recommended to change something in config file, when you don't know all the results of this action.
Also I`d like you to know that in future releases (probably 6.2) we will have feature that will allow you to change cache settings on the fly.
sunyucong
Wed Aug 15, 2012 9:19 pm
it's too late, i have been bitten by this, and soon realize this is probably the reason, sigh
Fri Aug 17, 2012 10:18 am
Well, at least you have improved your experience :)
