I have noticed since I installed version 6 that I have had a number of problems with de-duplicated disks following system crashes and reboots.
On restart the volumes show as uninitialised, the first time this happened I thought the problem was caused by a system crash so I rebuilt the disk.
This morning it has happened to two volumes (1TB and 4TB) following an orderly shutdown and reboot.
Can you advise if this is a problem you have seen before and if there is anything I need to change in order to stop it happen.
I am currently running V6.0.4703
Thanks and best regards
Nick
