How can change LUN?
georgeyu100
Tue Nov 06, 2012 8:24 pm
ON Starwind, while creating a new target, the LUN always is 0 wherever the storage is and how many and whether it is not not is a cluster. The LUN is created automatically by Starwind, and can't handle it by hands.
Is it a defect on Starwind as I have been told LUN can be set by hand? :?:
thanks,
Tue Nov 06, 2012 8:46 pm
It's not a "defect" it's by design. If you create one target and one LUN - it will be always zero. If you add more LUNs to the same target - their numbers will increment as you go.
georgeyu100 wrote:ON Starwind, while creating a new target, the LUN always is 0 wherever the storage is and how many and whether it is not not is a cluster. The LUN is created automatically by Starwind, and can't handle it by hands.
thanks,
georgeyu100
Tue Nov 06, 2012 10:07 pm
anton (staff) wrote:It's not a "defect" it's by design. If you create one target and one LUN - it will be always zero. If you add more LUNs to the same target - their numbers will increment as you go.
thanks,
Thank Anton for your quick response.
Could you give me detail how to add more LUNs to the same target? on Starwind, I can't find the function on Starwind, neither on VMware.
thanks again.
Tue Nov 06, 2012 10:27 pm
When you create a device and come up to the page asking about creating a new target choose adding to existing one option.
Tomorrow help guys will give you a screenshot or whatever.
thanks,
thanks again.
