Starwind Service shuts down - 2nd time
Tolahouse
Fri Jan 25, 2013 9:46 pm
I have a newly built starwind server put into production last month December. Twice now out of the blue the Starwind Service would stop rendering all luns unavailable. A simple restart service brings all functionality back, In the logs I see a lot of entries saying "PDU is dropped: CmdSN 0 is out of range (ITT 0x0)
What could be the cause of this.
Fri Jan 25, 2013 10:43 pm
StarWind version? What do you use to connect to target? What configuration do you have? HA non-HA? Do you happen to have a complete log?
iSCSI sends commands numbered (incremented) so there's no way initiator will send 0 cmd again. Something went wrong (session disconnected by initiator but not physically dropped by TCP stack for example). Very strange. Need log to figure out what's going on.
Tolahouse wrote:I have a newly built starwind server put into production last month December. Twice now out of the blue the Starwind Service would stop rendering all luns unavailable. A simple restart service brings all functionality back, In the logs I see a lot of entries saying "PDU is dropped: CmdSN 0 is out of range (ITT 0x0)
Tolahouse
Sun Jan 27, 2013 11:07 pm
Starwind is Version 6 running in Non HA mode on Windows 2008R2 connecting to ESX 4.1. I have emailed in the logs.
Sun Jan 27, 2013 11:12 pm
Good. Thanks. Please give engineers some time to check them and return to you.
Tolahouse wrote:Starwind is Version 6 running in Non HA mode on Windows 2008R2 connecting to ESX 4.1. I have emailed in the logs.
Tolahouse
Mon Feb 04, 2013 7:06 pm
Friendly Bump. Still waiting to hear from engineers.
Wed Feb 06, 2013 11:25 am
Hi! I see that starwind service has crashed and a minidump was created. Would you be so kind to send this file (C:\Program Files\StarWind Software\StarWind\starwind.20130125.155411.mdmp) to support@starwindsoftware.com?
Tolahouse
Thu Feb 07, 2013 2:22 pm
Do you have an FTP location. The compressed minidump file is 83MB, cannot send it via email.
Tolahouse
Sun Feb 10, 2013 5:31 pm
Bump.
Mon Feb 11, 2013 8:34 am
You are welcomed to upload compressed files to some file hosting service like this one or this one, and share the download link with us.
Thank you
Tolahouse
Mon Feb 11, 2013 2:45 pm
Link to files sent to support@starwindsoftware.com
Thank You.
Mon Feb 11, 2013 4:10 pm
Thank you sir!
I just want to let you know that your logs were forwarded to R&D. We will get back to yous asap.
Tue Feb 12, 2013 11:16 am
I have sent you the download link to the build that should fix your issue via the PM. Would you be so kind to install it and update us if it helped?
Tolahouse
Tue Feb 12, 2013 12:56 pm
Thank you. I will download it and install.
In the meantime can you tell me what you saw that was wrong with my setup. Another system built a day before or a day after this system is working fine with the same specs and same setup.
Tue Feb 12, 2013 2:23 pm
There was some issues with iSCSI commands processing in some cases, and you faced on of such unfortunately.
