HA iSCSI, which initiator address
sjender
Mon Feb 25, 2013 3:22 pm
I just setup my first 2-node StarWind HA iSCSI target.
But I'm a little confused now...
How can I connect to it to be 'HA'.
If I enter the IP address of one of the nodes, it's not HA.
Isn't there a dedicated IP address for the target?
Or am I overlooking something?
p.s. Is the iSCSI target active-active?
So the load is balanced between both nodes?
Max (staff)
Tue Feb 26, 2013 8:13 pm
The iSCSI target is active-active, so you need to add both IPs to the initiator when connecting to HA.
Please refer to these manuals for more information on the iSCSI initiator config:
http://www.starwindsoftware.com/providi ... or-hyper-v
http://www.starwindsoftware.com/providi ... or-vsphere
Max Kolomyeytsev
