Performance accessing iSCSI target
Locked
jkofr
Wed Mar 20, 2013 9:26 pm
I am new user in discovery mode with StarWind :-)
I am an Oracle DBA Architect and I am dealing a lot with oracle RAC configuration. To do my test I need some VM and shared storage capabilities.
Here is my config:
Host is Windows 2008 R2 with 2* Xeon E5530 and 32 Gb of RAM with Two Areca SAS controlers and a bunch of HD.
All my VM are under VMWare workstation 9
Before I was using OpenFiler for iSCSI target configuration. It works fine but the I/O bandwith is very poor.
My RAC config is as follow:
One DNS server under OEL linux
One Storage Server Openfiler 2.99
5 nodes under OLE Linux
Oracle 11gR2 Grid and Database
Just for testing, I have defined a cluster filesystem using ASM capabilities on a target hosted by my OpenFiler VM.
Coping a 990MB file takes nearly 30 seconds, not so good.
I have installed StarWind on my Windows 2008 R2 host and have defined a target on an image disk just for test, enable cluster access, put 256Mb of cache and from one of the node connected to the target.
To copy the same file it take 2 minutes... What's wrong here?
For information it take nearly 27 seconds from an other VM Windows 7 also from vmware workstation.
Thanks for your help
jko
jkofr
Thu Mar 21, 2013 7:25 am
Is something unclear?
Thanks for your help.
Thu Mar 21, 2013 4:18 pm
Hi and welcome on board :D
I need to know the following information from you in order to provide a solution:
1. What StarWind device type was used in the test (i.e. Image file, CDP, Deduplication)?
2. RAID array model, RAID level and stripe size used, caching mode of the array used to store HA images, Windows volume allocation unit size
3. NIC models, driver versions (driver manufacturer/release date) and NIC advanced settings (Jumbo Frames, iSCSI offload etc.)
4. Network scheme.
Also, there is a document for pre-production SAN benchmarking:
http://www.starwindsoftware.com/starwin ... ice-manual
And a list of advanced settings which should be implemented in order to gain higher performance in iSCSI environments:
http://www.starwindsoftware.com/forums/ ... t2296.html
Please provide me with the requested information and I will be able to further assist you in the troubleshooting
jkofr
Thu Mar 21, 2013 8:42 pm
Hi Thanks,
My problem is not related to starwind, but network configuration from vmware...
I am investigating.
jko
Thu Mar 21, 2013 10:50 pm
Good. Please keep us updated. We'd love to help on request.
jkofr wrote:Hi Thanks,
I am investigating.
jko
divyamane
Fri May 31, 2019 11:27 am
My concern isn't identified with starwind, yet organize setup from VMware...
Fri May 31, 2019 11:28 am
Please spawn a separate thread for your issue. There's no point to "update" something which is 6+ years old. Thank you for understanding!
== thread locked ==
divyamane wrote:My concern isn't identified with starwind, yet organize setup from VMware...
Locked
