Hi Guys,
I had a drive starwind dedupe drive stop working after a server reboot so I restored the drive from backup. When trying to remount the drive I get Invalid Storage selected Error 13. I have restored drives in the past without any issue but for some reason this one I can't get working. Below is the part in the log file relating to the mounting. Any help would be appreciated.
7/1 22:36:04.859 890 conf: Target [0x0000000001A016D0] 'iqn.2008-08.com.starwindsoftware:sdalumsvr012.pngum.local-dctest' has been created, 0 devices attached.
7/1 22:36:04.859 890 conf: Reaction of type 'eventlog' [0xFFFFFFFF, 0x0C] loaded successfully.
7/1 22:36:04.859 890 conf: Variable 'DefaultAccessPolicy' is set to 'allow'.
7/1 22:36:04.859 890 Srv: Update tracker options: UpdatePeriod = 7, UpdateLastRequest = 20130701, UpdateHost = www.starwindsoftware.com, UpdatePage = /updatetracker/index.php, UpdatePort = 80, UpdateCopyId = CBDA2883-D92A-411D-9245ABE7A1489DA3
7/1 22:36:04.859 890 Srv: Refreshing device list (complete)...
7/1 22:36:04.890 890 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&1982005&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 0, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
7/1 22:36:04.953 890 PerformanceDB: CPerformanceCounter::WriteOperationalData called on uninitialized counter(DB entry: 0000000000000000, Record: 0000000000000000).
7/1 22:36:04.953 890 PerformanceDB: CPerformanceCounter::Close exiting with error: WriteOperationalData failed.
7/1 22:36:04.953 890 SPTI: '\\?\scsi#disk&ven_vmware&prod_virtual_disk#5&1982005&0&000200#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 ': adapter 2, bus 0, target 2, LUN 0; maxTransferLength 16777215, alignmentMask 0x0
7/1 22:36:04.953 890 SPTI: '\\?\ide#cdromnecvmwar_vmware_ide_cdr10_______________1.00____#5&290fd3ab&0&1.0.0#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': ' NECVMWar VMware IDE CDR10 1.00': adapter 1, bus 1, target 0, LUN 0; maxTransferLength 131072, alignmentMask 0x1
7/1 22:36:04.953 890 Srv: Found SPTI device '\\?\ide#cdromnecvmwar_vmware_ide_cdr10_______________1.00____#5&290fd3ab&0&1.0.0#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': ' NECVMWar VMware IDE CDR10 1.00'
7/1 22:36:04.953 8e4 conf: Waiting for Control connections at 0.0.0.0:3261 ...
7/1 22:36:04.953 990 bc: Waiting for broadcast UDP packets at 0.0.0.0:3261...
7/1 22:36:04.953 890 Srv: Waiting for iSCSI connections at 192.168.240.2:3260 ...
7/1 22:36:04.953 890 Srv: Waiting for iSCSI connections at 127.0.0.1:3260 ...
7/2 6:36:54.198 8e4 conf: Accepted control connection from 127.0.0.1:63278.
7/2 6:37:16.912 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:37:18.269 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:37:18.269 c9c Sw: *** Browser_ParsePath: Incorrect path supplied: 'Metadata\D\Data1\Data1.spmetadata'!
7/2 6:37:18.269 c9c Sw: *** Control_GetFileSize: Could not retrieve directory info!
7/2 6:37:18.269 c9c FileBrowser: Return param: 'FileSize' = 'Failed: invalid path provided'
7/2 6:37:18.284 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:37:18.284 c9c Sw: *** Browser_ParsePath: Incorrect path supplied: 'Metadata\D\Data1\Data1.spmetadata'!
7/2 6:37:18.284 c9c Sw: *** Control_GetFileSize: Could not retrieve directory info!
7/2 6:37:18.284 c9c FileBrowser: Return param: 'FileSize' = 'Failed: invalid path provided'
7/2 6:37:18.362 c9c Sp: *** CStarPackCore::CreateEx 13 Data header tag is invalid
7/2 6:37:18.362 c9c Sp: --- CStarPackCore::CreateEx (line #2815) 13
7/2 6:37:18.362 c9c Sp: --- CStarPackSemaphore::MultiSignal 487 SpSemaphoreObjectSignal( 0x0000000000000000, 16 ) 487
7/2 6:37:18.362 c9c Sp: --- CStarPackSemaphore::MultiSignal (line #280) 487
7/2 6:37:18.362 c9c Sp: --- SpCoreObjectCreateFromParams 13 *ppCore->pCore->Create( 0x00000000015E8CA8 ) 22973616
7/2 6:37:18.362 c9c Sp: --- SpCoreObjectCreateFromParams (line #7704) 13
7/2 6:37:18.362 c9c Sw: *** DDDisk_ControlIsStorageValid: Create SP object failed, status ( 13 ) - 'Invalid data'.
7/2 6:43:35.635 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:43:37.211 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:43:37.211 c9c Sw: *** Browser_ParsePath: Incorrect path supplied: 'Metadata\D\Data1\Data1.spmetadata'!
7/2 6:43:37.211 c9c Sw: *** Control_GetFileSize: Could not retrieve directory info!
7/2 6:43:37.211 c9c FileBrowser: Return param: 'FileSize' = 'Failed: invalid path provided'
7/2 6:43:37.226 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:43:37.226 c9c Sw: *** Browser_ParsePath: Incorrect path supplied: 'Metadata\D\Data1\Data1.spmetadata'!
7/2 6:43:37.226 c9c Sw: *** Control_GetFileSize: Could not retrieve directory info!
7/2 6:43:37.226 c9c FileBrowser: Return param: 'FileSize' = 'Failed: invalid path provided'
7/2 6:43:37.258 c9c Sp: *** CStarPackCore::CreateEx 13 Data header tag is invalid
7/2 6:43:37.258 c9c Sp: --- CStarPackCore::CreateEx (line #2815) 13
7/2 6:43:37.258 c9c Sp: --- CStarPackSemaphore::MultiSignal 487 SpSemaphoreObjectSignal( 0x0000000000000000, 16 ) 487
7/2 6:43:37.258 c9c Sp: --- CStarPackSemaphore::MultiSignal (line #280) 487
7/2 6:43:37.258 c9c Sp: --- SpCoreObjectCreateFromParams 13 *ppCore->pCore->Create( 0x00000000015E8CA8 ) 22973616
7/2 6:43:37.258 c9c Sp: --- SpCoreObjectCreateFromParams (line #7704) 13
7/2 6:43:37.258 c9c Sw: *** DDDisk_ControlIsStorageValid: Create SP object failed, status ( 13 ) - 'Invalid data'.
7/2 6:46:03.128 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:46:04.360 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:46:04.360 c9c Sw: *** Browser_ParsePath: Incorrect path supplied: 'Metadata\D\Data1\Data1.spmetadata'!
7/2 6:46:04.360 c9c Sw: *** Control_GetFileSize: Could not retrieve directory info!
7/2 6:46:04.360 c9c FileBrowser: Return param: 'FileSize' = 'Failed: invalid path provided'
7/2 6:46:04.376 c9c FileBrowser: Return param: 'FileSize' = '208401879040'
7/2 6:46:04.376 c9c Sw: *** Browser_ParsePath: Incorrect path supplied: 'Metadata\D\Data1\Data1.spmetadata'!
7/2 6:46:04.376 c9c Sw: *** Control_GetFileSize: Could not retrieve directory info!
7/2 6:46:04.376 c9c FileBrowser: Return param: 'FileSize' = 'Failed: invalid path provided'
7/2 6:46:04.392 c9c Sp: *** CStarPackCore::CreateEx 13 Data header tag is invalid
7/2 6:46:04.392 c9c Sp: --- CStarPackCore::CreateEx (line #2815) 13
7/2 6:46:04.392 c9c Sp: --- CStarPackSemaphore::MultiSignal 487 SpSemaphoreObjectSignal( 0x0000000000000000, 16 ) 487
7/2 6:46:04.392 c9c Sp: --- CStarPackSemaphore::MultiSignal (line #280) 487
7/2 6:46:04.392 c9c Sp: --- SpCoreObjectCreateFromParams 13 *ppCore->pCore->Create( 0x00000000015E8CA8 ) 22973616
7/2 6:46:04.392 c9c Sp: --- SpCoreObjectCreateFromParams (line #7704) 13
7/2 6:46:04.392 c9c Sw: *** DDDisk_ControlIsStorageValid: Create SP object failed, status ( 13 ) - 'Invalid data'.
