Thick Provisioned HA Node not synchronised
Guy Liu
Fri Feb 27, 2015 10:31 am
I am running the Free 2 Node Hyper-V version of the StarWind Virutal SAN.
When I create a thick provisioned HA device, and the device shows up no problem and the status indicates that the partners are in sync.
The minute I attach my Hyper-V server to the two nodes, the device becomes unsynchronised and won't re-sync. On the iSCSI config of the hyper-v server one of the nodes shows "connected" but the other shows "Reconnecting".
I can reliably reproduce this behavior. This happens on build 7509 as well as the build 7774 that's released today.
This only seem to happen to Thick provisioned devices, but not thinly provisioned devices. The hyper-v server has MPIO enabled and configured, and I can setup cluster OK if all devices are thinly provisioned.
Is this the intended behavior or have I done something wrong?
Wed Mar 04, 2015 9:43 am
Hi! Sorry to hear that you are in trouble.
1. Can you double check if you have followed out manuals precisely?
2. Have you checked the logs?
