Creating an HA target in v8, slightly confused...
mooseracing
Wed Sep 09, 2015 12:12 pm
I hate to admit it, but the options I am looking for seem to be not where I am expecting. We've been running a 2 server HA setup with multiple HA targets for a few years now. I've finally been able to start replacing some Platter drives with SSD's and am trying to create to HA targets and devices.
I used to be able to choose an advanced device and choose HA, now I don't seem to have that option. Where is the HA choices in v8?
This doc is what I remember, pg 6 and on https://www.starwindsoftware.com/images ... yper-V.pdf
darklight
Thu Sep 10, 2015 3:10 pm
In v8 you just create a standalone device and then convert it to HA by replicating to another server using replication manager.
mooseracing
Fri Sep 11, 2015 6:32 pm
Thanks for that.
Trying to create a device, choose thin and set my options, when choosing location and the window opens I have nothing displayed. If I manually enter a location and walk through the wizard I will get "failed to create device" . Same for either node.
I can create a disk bridge device though without any issue.
mooseracing
Fri Sep 25, 2015 6:41 pm
Thanks, not sure how I didn't come across that while I was digging. Got a little further than ran into some more issues with Starwind before I could finally get through the replication manager wizard.
I wonder if alot of it stems from just upgrading previous versions since we started with Starwind. Either way we'll see this winter as I am hoping to refresh our 2 Disk Nodes with an upgrade form '08 to 2012R2 and maybe a little RAM increase.
Nice to see a two disk SSD RAID1 using half my 10Gb channel for sync. :mrgreen:
Rajesh.Rangarajan
Mon Sep 28, 2015 12:08 pm
The reason you are getting a half of your sync performance is that your SSDs are most probably connected through SATA3 interface which can only handle up to 6GBps throughput.
Tarass (Staff)
Fri Nov 13, 2015 4:32 pm
Anything here left unresolved that I could help with?
StarWind Software Inc.
