Hi Guys,
I heard of Star Wind virtual San some time ago, but never found a project I could use it for or test with.
This is no longer the case, as I have a small lab I am trying to set up and I think Virtual San FREE could fit the bill.
I am trying to set up a two node Windows 2012 R2 file server cluster. I have two file server VMs running in Hyper-V on my Windows 10 machine. I need to attach some shared storage to them, and I think iSCSI disks should do the trick.
So I installed Virtual SAN free on my PC, created a target, and attached a disk to it. Great! I can mount that disk to both file servers without issue.
The issue now is, if I drop some files on that volume from one VM, they do not appear on that volume on the other. If I offline and then online the disk, they show up, but then Windows the volume needs scanning and repair.
Is this a possible setup, or do I have to do the two node Virtual SAN, with replication between the two, and point one VM to each?
Many thanks
Eds
