Two nodes HA GUI vs Powershell
artidens
Sun Apr 01, 2018 9:42 pm
This is driving me crazy. If I create an HA device with Powershell using the two nodes HA script provided in the samples directory, it will be shown as two separate disks in my vSphere. But if I create a similar HA device using the GUI, it is shown correctly as just one disk so I can configure multipathing etc. What might be causing this?
Also, I have two nodes and for some reason node1 trial license has already expired, so I cannot manage it with the GUI. Installed Starwind VSAN Free on both nodes today.
Mon Apr 02, 2018 8:57 am
Unfortunately, the latest build is confirmed to have an issue with the StarWindX functionality in terms of creating more than one HA device from PowerShell. The R&D team has already fixed this issue and the fix will be published as a part of the next build released.
Petas3
Tue Apr 10, 2018 4:07 pm
I have encountered this nasty issue - its easily fixed once you know where the problem is. The key is to specify the same device id for both nodes, this has to be forced explicitly:
eg.
$firstNode.SerialID = "050176c0b535403ba3ce02102e33eac"
$secondNode.SerialID = "050176c0b535403ba3ce02102e33eac"
In the script this is missing..
Let me know if it worked for you :)
Wed Apr 11, 2018 8:00 am
This may do the trick until the official release.
