Do you have any research showing a graph of ram to performance for a “average” iSCSI server? We’re speccing out a 15 drive system , dual opteron and wondering if RAM would really be used or should we just go with maybe 2gb (max is 16gb in server).
I’m not sure how well windows / starwind will take advantage of the ram is why this question - I know windows will use it if it's there, but will Starwind itself take advantage of it any at all?
I do know it’s kind of a hard to answer question, depending on the data on this server, but just a average benchmark of how it does, specifically through starwind (incase that changes any NT cache algorithms) would be very helpful. Perhaps a standard benchmark run against a server trying it with 1 gb, 2gb, 4gb, 8gb of ram and seeing the difference.
