StarWind VSAN for vSphere questions
primo
Thu Mar 18, 2021 8:33 pm
I have some questions regarding StarWind VSAN for vSphere:
- how can I check the version of currently installed StarWind VSAN for vSphere?
- when a new version comes out, how can I update it?
- is the fact that CentOS will not be free anymore going to change anything?
- what is the role of performance profiles?
- is it possible to set up NTP synchronization?
Thank you!
Best Regards,
primo
Fri Mar 19, 2021 3:43 pm
Go to StarWind Management Console -> Select the server -> Configuration -> register. OR open any log file in /opt/StarWind/StarWindVSA/drive_c/StarWind/logs
Here is the guide https://knowledgebase.starwindsoftware. ... d-version/. If your VMs have no internet connection, just import the upload file via WinSCP.
Please keep an eye on release notes. For now, everything is alright as is.
See more at https://www.futurehosting.com/blog/opti ... ith-tuned/. This setting is fine to be left as is.
May I ask you to check if StarWind VM has access to the ntp servers specified in "chrony.conf" file? You can get them using the command: cat /etc/chrony.conf
primo
Thu May 13, 2021 5:40 pm
was the build 14033 for VMware pulled back? I've tried to update from build 13861, but the updater says that the latest version is already installed.
Is it ok to use the Console build 14033 for VMware VSAN with build 13861? I cannot find the Console build 13861 anywhere.
primo
Fri May 14, 2021 11:27 am
I have the previous console version now - thanks to excellent StarWind support! 8), but it would be interesting to know what's with the 14033 build now.
Fri May 14, 2021 11:42 am
HI,
The next build should be available in June. Stay tuned! Contact me here if you have any questions.
primo
Mon May 17, 2021 5:31 pm
Do you still recommend setting the following on both ESX nodes?
esxcli storage nmp psp roundrobin deviceconfig set --type=iops --iops=1 --device=eui.someid
Tue May 18, 2021 3:29 am
Yes. That parameter is set with the rescan script for StarWind HA devices.
