About add device (Advance)
vmware
Sat Apr 08, 2023 5:49 am
When click add device (Advance) now, in the Virtual Device options interface, there are no options for deduplication or Thick setting configuration of the disk. Have you canceled??
Sun Apr 09, 2023 1:39 pm
Thank you for your question.
Yes, LSFS was depreciated in the latest releases. Also, assuming that your question relates to StarWind VSAN for vSphere, dedupe, on StarWind VSAN level, was never present in StarWind VSAN for vSphere.
vmware
Mon Apr 10, 2023 7:56 am
So the snapshot function and deduplication function are no longer effective on starwind for hyper-v?
Mon Apr 10, 2023 8:15 am
It is depreciated now. You try setting up VDO in StarWind VSAN for vSphere VM if you need deduplication (https://www.starwindsoftware.com/resour ... iguration/).
keyportfolio
Tue May 30, 2023 4:27 am
yaroslav (staff) wrote:It is depreciated now. You try setting up VDO in StarWind VSAN for vSphere VM if you need deduplication (https://www.starwindsoftware.com/resour ... iguration/).
It's easy to get into the VM and learn
Tue May 30, 2023 7:25 am
Not sure what you mean.
