V2V VMware to Hyper-V Failing
tommytwotone
Fri Mar 14, 2025 11:21 pm
Also, here is the log from the error in previous Post:
3/14 16:01:21.158 1d38 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
3/14 16:01:21.158 1d38 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.623
3/14 16:01:21.174 1d38 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
3/14 16:01:21.174 1d38 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
3/14 16:01:21.174 1d38 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
3/14 16:01:21.174 1d38 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - dc6c0000
3/14 16:01:33.596 1d38 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
3/14 16:02:28.518 3d78 Facility ???INFO: WrapperESXI::connect: m_url - https://asbcolvcs03/sdk
3/14 16:02:28.721 3d78 Facility ???INFO: WrapperESXI::connect: fullName - Administrator asbcolvcs03.local, key - 521cc469-196c-f7d4-0150-dae04596d4c7
3/14 16:02:28.737 3d78 Facility ???INFO: VMConverter::ESXIConverter::Connection: No_timeout ESX connection
3/14 16:02:28.737 33cc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_45e10b95ea75dd0c0340da46e5ffb3a1>::operator (): Worker thread started.
3/14 16:02:28.737 1d38 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
3/14 16:02:30.081 1d38 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/14 16:02:30.081 1d38 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/14 16:02:30.081 1d38 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/14 16:02:44.690 1d38 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
3/14 16:02:44.690 1d38 Facility ???ERROR: WrapperESXI::getGuestOS: IsValidResponse m_morComputeResource environmentBrowser false
3/14 16:02:44.690 1d38 Facility ???WARNING: WrapperESXI::getVMList: getGuestOS fail - -1
3/14 16:02:53.393 1d38 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
3/14 16:03:35.768 1d38 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
3/14 16:03:40.362 1d38 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsAWS
3/14 16:03:53.612 2cfc Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
3/14 16:03:53.659 2cfc Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.17763
3/14 16:03:53.659 1d38 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eSelectFolder
3/14 16:04:49.753 1d38 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
3/14 16:04:49.769 44b0 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
3/14 16:04:49.769 44b0 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: [ASBCOLVSI01-DS01] test - Win2019-Std-TPL/test - Win2019-Std-TPL.vmdk, pathOutput: D:\VMs\fromVMware\test - Win2019-Std-TPL\Virtual Hard Disks\test - Win2019-Std-TP.vhd
3/14 16:04:49.847 44b0 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [ASBCOLVSI01-DS01] test - Win2019-Std-TPL/test - Win2019-Std-TPL.vmdk
3/14 16:04:49.847 44b0 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-6296
3/14 16:04:49.847 44b0 Facility ???INFO: VMDK_API_Wrapper::getSslThumbprint: Resolving domain name - asbcolvcs03, resolved ip - 10.61.96.20
3/14 16:04:49.847 44b0 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 5A:D6:9B:CA:38:F4:B5:73:B0:E6:07:79:E1:8A:DA:1F:6A:6B:41:57
3/14 16:05:06.159 44b0 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
3/14 16:05:06.737 44b0 Facility ???ERROR: CVHDXFile::NewFile: File extension is not VHDX.
3/14 16:05:06.737 44b0 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 13
3/14 16:05:06.753 44b0 Facility ???ERROR: CPPConverting::Convert: FAILED
3/14 16:07:28.754 33cc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_45e10b95ea75dd0c0340da46e5ffb3a1>::operator (): Timeout ESX connection. Performing updates.
3/14 16:12:28.755 33cc Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_45e10b95ea75dd0c0340da46e5ffb3a1>::operator (): Timeout ESX connection. Performing updates.
ashaw
Sat Mar 15, 2025 12:25 am
I am also having this exact same issue. Can anyone confirm that the old version works?
Sat Mar 15, 2025 8:38 am
I will being logs to the devs thanks!
WMCI20
Sat Mar 22, 2025 10:33 pm
I am adding to this thread for others. I can confirm error with version 9.0.1.623. These lines appear in log file:
I have tried on two DIFFERENT ESXi hosts at two DIFFERENT sites.
Thank you for this forum as I did download version 9.0.1.268 and also am converting as I write this.
Making the previous version available was SO VERY helpful to us who do these types of migrations on weekends.
Much appreciated.
Sun Mar 23, 2025 8:35 pm
Thanks for your post.
The previous version is on the forum. Everyone is welcome to use it.
Does the VM have a thin disk or a thick one? What is the output format (fixed/dynamic)? Do you convert a VM or a disk?
What are the ESXi and Windows versions?
Does the VM have snapshots? Is it a live conversion?
Fri May 09, 2025 7:13 pm
Try the latest build, please.
