Unable to login to management console after uname/pwd change
Glenn
Sat Nov 14, 2009 2:40 pm
Dear,
I just succesfully tried the StarWind iScsi target on my home network. Everything seems to work just fine.
As indicated during the installation, I changed the username and the password for logging in to the management console of the target. I entered a new set of credentials, but with a quite elaborate password. When I try to log in now, I can't enter this lengthy password, only 8 characters seem to be allowed.
Is this a know bug, intended by design, and most of all correctable?
Thanks in advance,
Kind regards,
Glenn
Robert (staff)
Mon Nov 16, 2009 1:21 pm
This was a known issue. Try to update your build of StarWind (just download the trial version from the web site and apply your license).
Robert
StarWind Software Inc.
IHawkMike
Tue Dec 15, 2009 5:01 pm
I just downloaded the newest version and am having this problem. Reinstalling doesn't help.
Any other ideas?
Constantin (staff)
Fri Jan 15, 2010 3:19 pm
Have you resolved your issue?
