Cannot Start service after power failure
SurvBaseAK
Fri May 21, 2010 1:36 am
We had a fairly lengthy power failure today and I am now unable to start the service. Running server 2008 R2, and the latest of Starwind iSCSI free. When I try to connect to server through the console, or manually start the service, the system hangs and a reboot is required to regain control. The only error that I get is that the service failed to respond in a timely manor. Any help would be appreciated.
Fri May 21, 2010 11:25 am
Could you be so kind to let us review StarWind logs generated on attempts to start the service? Please zip the logs and send them to support@starwindsoftware.com or attach (rather then cut-n-paste in the message) here. Then we'll be able to tell what's wrong. Thank you!
SurvBaseAK wrote:We had a fairly lengthy power failure today and I am now unable to start the service. Running server 2008 R2, and the latest of Starwind iSCSI free. When I try to connect to server through the console, or manually start the service, the system hangs and a reboot is required to regain control. The only error that I get is that the service failed to respond in a timely manor. Any help would be appreciated.
