Hola!
Have the same problem: two disks are being seen as one with different paths in ESX 4.1
Hardware: hp MSA1000 connected to a hp dl380g3 with win2008x86 by fc; one array with 14 physical drives and two logical drives. Starwind 5.5.1638
Logical drives are configured by native hp array configuration utility:
first one
Status OK
Drive Number 1
Drive Unique ID 600805F300078B70AD7E73BBD6750018
Size 871192 MB
Fault Tolerance RAID 1+0
Heads 255
Sectors/Track 32
Cylinders 65535
Strip Size 128 KB
Array Accelerator Temporarily Disabled
Disk Name \\.\PhysicalDrive1
second one
Logical Drive
Status OK
Drive Number 3
Drive Unique ID 600805F300078B70AE27716CF720001D
Size 890880 MB
Fault Tolerance RAID 5
Heads 255
Sectors/Track 32
Cylinders 65535
Strip Size 64 KB
Parity Initialization Status In Progress
Disk Name \\.\PhysicalDrive3
target one:
target name = iqn.2008-08.com.starwindsoftware:127.0.0.1-vmclu1
device name = \\?\scsi#disk&ven_compaq&prod_msa1000_volume#4&232fafe&0&000001#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
target two:
target name = iqn.2008-08.com.starwindsoftware:127.0.0.1-stages
device name = \\?\scsi#disk&ven_compaq&prod_msa1000_volume#4&232fafe&0&000003#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
ESX works perfectly with the first one. But when I try to add one more disk, I have disks with the same device eui: eui.1e313422a9e9f99f
iqn.1998-01.com.vmware:vs07-43ab4c47-00023d000001,iqn.2008-08.com.starwindsoftware:127.0.0.1-stages,t,-1-eui.1e313422a9e9f99f
Runtime Name: vmhba34:C0:T1:L0
Device: eui.1e313422a9e9f99f
Device Display Name: COMPAQ iSCSI Disk (eui.1e313422a9e9f99f)
Adapter: vmhba34 Channel: 0 Target: 1 LUN: 0
Adapter Identifier: iqn.1998-01.com.vmware:vs07-43ab4c47
Target Identifier: 00023d000001,iqn.2008-08.com.starwindsoftware:127.0.0.1-stages,t,-1
Plugin: NMP
State: active
Transport: iscsi
Adapter Transport Details: iqn.1998-01.com.vmware:vs07-43ab4c47
Target Transport Details: IQN=iqn.2008-08.com.starwindsoftware:127.0.0.1-stages Alias= Session=00023d000001 PortalTag=1
iqn.1998-01.com.vmware:vs07-43ab4c47-00023d000001,iqn.2008-08.com.starwindsoftware:127.0.0.1-vmclu1,t,-1-eui.1e313422a9e9f99f
Runtime Name: vmhba34:C0:T0:L0
Adapter: vmhba34 Channel: 0 Target: 0 LUN: 0
Target Identifier: 00023d000001,iqn.2008-08.com.starwindsoftware:127.0.0.1-vmclu1,t,-1
Plugin: NMP
State: active
Transport: iscsi
Target Transport Details: IQN=iqn.2008-08.com.starwindsoftware:127.0.0.1-vmclu1 Alias= Session=00023d000001 PortalTag=1
