Windows registry modifications when using HP Team bonded if
eaperezh
Thu Feb 10, 2011 12:56 pm
I would like to know if the recomendations to modify the registry in windows 2003/2008 from this post:
http://www.starwindsoftware.com/forums/ ... t2293.html (section windows tweaks),
works or are ignored when the starwind server is using a bonded interface created by the HP Team utility. Also, a LACP etherchannel on the switch side was created. The jumbo frames were enabled in the HP Team utility for the bonded interface.
Thu Feb 10, 2011 4:05 pm
TCP settings are global.
You may need to play with Jumbo frame size. Also no idea how sufficient HP teaming implementation is.
eaperezh wrote:Hi,
