Access Rights Rules Appearing
rchisholm
Mon May 09, 2011 9:04 pm
I've found that when I reboot a StarWind server, the Access Rights that I have deleted come back. Also, rules that I have added additional destinations to have a copy for every configuration of the rule that has existed. So, If I create an Access Rights rule with a single destination, then edit it 9 times adding a single destination each time, after a reboot there are 10 rules with the same Rule Name. 1 will have 1 destination, another will have 2 destinations, another will have 3 destinations,........etc. Anyone else running into this?
hixont
Tue May 10, 2011 5:10 pm
Yes, I just delete the extraneous rules.
I also ran into a problem where I couldn't edit existing rules, but an upgrade to a current version (at that time) fixed that problem.
Wed May 11, 2011 7:30 am
You can download it using the link below:
http://www.starwindsoftware.com/download-free-trial
davidsperanza
Tue Aug 30, 2011 11:38 pm
Hi guys
I have the same problem but I'm running version 5.6.1659
Is there any explaination why this is happening? Is there a fix?
Cheers
David
Wed Aug 31, 2011 10:30 am
Version you use is outdated. Update to at least V5.7 to see the difference.
