Solution to sync SAN1 to SAN2
Dana2011
Fri May 27, 2011 3:10 pm
What is better solution to connect SAN1 to SAN2 for sync; I have two channels for sync SAN1 to SAN2
- connect SAN1 to SAN2 with a straight trough cables from NICs
- connect SAN1 to SAN2 whit crossover cables
Or connect SAN1 with SAN2 trough Switch; I have Dell PowerConnect 6248.
Thanks for any advice!
Fri May 27, 2011 3:17 pm
No hardware = nothing to fail. For sync channels use cross-over cables if possible. They are cheaper, faster and copper is more reliable then baked silicon :)
Dana2011
Sat May 28, 2011 1:49 am
I also want to know if the chanels for sync have to be in different subnets.
Thank you,
Dana
Sun May 29, 2011 10:16 am
You really need to have sync channels configured using different set of hardware (switches, NICs and cabling) to provide redundancy. Software configuration (subnets, VLANs etc) does not matter at all.
Dana2011 wrote:I also want to know if the chanels for sync have to be in different subnets.
Thank you,
Dana
Dana2011
Mon May 30, 2011 3:31 pm
Thanks a lot !
Dana
Mon May 30, 2011 4:09 pm
Tiny correction: if your hypervisor of choice is ESX you'd better stick with the DIFFERENT subnets.
