3 Node Cluster Design
CCI
Sun Mar 17, 2013 9:51 pm
I am looking to upgrade my current Hyper-V Native SAN cluster from 2 nodes each with 6 x 1gbps nics, to 3 nodes each with 4 x 1gbps nics and 1 x dualport 10gbps nic.
I have been reading about Windows server 2012 virtual network improvements for some time, and Like what I am reading.
I created some diagrams to demonstrate 2 of the many possible ways to hook it all together. Keep in mind these are initial drafts..
http://www.gliffy.com/go/publish/4404348/
http://www.gliffy.com/go/publish/4406080/
I am wondering if anyone else here is working with a similar setup, and if anyone see's any major issues with this design.
Also I would need to know if this is supported from Starwind Software.
eickst
Mon Mar 18, 2013 12:59 am
2012 has issues with CSV backups, regarding DPM (or any vss I think).
That's why we are sticking with 2008 for now. We use DPM extensively so we can't really go with an unsupported setup.
I will say that clustering and csv was a lot easier to configure on 2012 than 2008R2.
Max (staff)
Wed Mar 20, 2013 11:40 am
Eickst, Thanks for your input!
Max Kolomyeytsev
