downloads
serverworks
Wed Mar 20, 2013 7:41 pm
I need version 4.x and 5.0 5.1 downloads as our server crashed with them on and we no longer have them please can some one help
Thu Mar 21, 2013 11:25 am
Unfortunately we do not distribute those versions anymore and that is why we do not stor them as well.
I can only recomend you two options:
-Renew your ASM, and you will be able to update your SAN software
-Try to find the version that you require in the Web
I hope it helped
lohelle
Thu Mar 21, 2013 11:33 am
I guess even the free edition could replace a server running version 4? That was before HA etc.
Max (staff)
Thu Mar 21, 2013 1:57 pm
I would agree with Lohelle,
for V4 - free edition does the job (unless you're running mirroring)
For V5 - if you're running HA, I strongly recommend to renew your ASM and update to the latest version. Handling HA in V5.0 by yourself is not the safest thing to do without proper support. Personally I would delegate this task to a qualified technician. Just my $ 0.02
Max Kolomyeytsev
