cannot install tape redirector on xp
chriswal
Sat May 25, 2013 5:47 pm
Hi ,
when i try to install tape redirector on xp sp3 only the management console is installed.
also on full install. is tape redirector not supported on xp?
is this a bug in the installer? is there any command line argument to select the components?
thanks
Sat May 25, 2013 6:13 pm
Ancient XP is supported for Management Console use only. Use more recent Windows (Vista & 8) or better stick with server rather then desktop ones.
chriswal
Sat May 25, 2013 9:17 pm
Thanks for the reply. Havent found any requirement page.
My tape drive is really old and i need old drivers. so i tried to install xp.
should have known before ..took me half a day to install all updates ;-)
i will try win 7 and hope the tape drivers will work
Sat May 25, 2013 10:24 pm
