we are doing performance tests on starwind using deduplicate iscsi image on ESX 4.1 server.
The results showed considerable changes, depending on max file size and block size configuration.
What i have now is a hardware Raid10 4TB with 2 x 2TB deduplicate images 1024mb cache
And on ESX server i configured:
1. deduplicate image 2TB with Maximum File Size: 256GB and block size:1MB
2. deduplicate image 2TB with Maximum file siez: 2048GB and block size:8MB
and i noticed that the 2nd setup was much faster..
Would a file size of 1TB even faster?
Does the blocksize make a difference?
The block size defined in starwind is it the same?
Can you give me a recommendation what is the best configuration for a 2TB image on an ESX server ?
Thank you very much!
