JGiordano
Mon Jun 24, 2013 11:22 pm
I running V6.0.5569 with a free license which to my understanding I'm able to have an unlimited amount of 128GB HA disks.. i dont need any one machine to be more then 128GB so the free version should de exactly what i need.
I currently have 1 Quorum disk of 1.0GB and a test box of 60.0GB
I'm trying to create another Target disk of 127.0GB for a Web Server. but i get the following error message
Total storage size exceeds the licensed storage capacity on the current host!
Licensed Storage capacity: 131072 MB. Total storage capacity in use: 62464MB
I dont understand what's going on here... can anyone help me out with this?
mahuan1688
Tue Jun 25, 2013 3:49 am
Estimation is authorized to achieve the maximum capacity limit. I can send you a 30 days from the date of the authorization, or you can go to the site of application.QQ:41396720
Tue Jun 25, 2013 9:38 am
Hi!
Well, its simple here:
1.0GB (Quorum) + 60.0GB (test box) + 127 GB (new target) is approximatelly equal to 1.5 of the capacity limitation. You should have somewhere around 67 GB of free space.
I hope it helped.
mahuan1688, would you please clarify what do you mean?
JGiordano
Tue Jun 25, 2013 1:37 pm
So the storage is a total of 128 GB for ALL HA "Disks" not 128 size restriction PER HA Disk.. bummer!
Tue Jun 25, 2013 1:47 pm
I`m sorry for not beeing exact - 128 is for HA only.
Waht device types are you using please?
