Altaro Backup / redirected I/O with CSV
raymondjt
Wed Jan 08, 2014 9:02 pm
we have a 2node Win2008R2SP1 failover cluster, which have CSVs on two Starwind v6 HA over 4x1Gbps iSCSI connection.
Making Hyper-V backups with Altaro make a VSS snapshot and takes quit a long time (up to 4hr) for one vm.
What is wrong?
What about your VSS provider software? It is not installed yet.
Would the VSS provider software reduce the time / load / impact of backups?
If yes, can we install the VSS provider software without any big changes on the HA environment?
THX
Raymond
Wed Jan 08, 2014 9:21 pm
This is normal with V6. V8 will have updated hardware VSS for both LSFS and FLAT (ex-Image Files) so there would be no redirected mode with any backup: VEEAM, Altaro, Symantec etc. Please stay tuned!
mahuan1688
Thu Jan 09, 2014 4:38 am
Then officially released version of V8 Is it right? No backup part, or the testing stage did not provide. Thank you.
Thu Jan 09, 2014 10:41 am
VM backup engine was licensed and would be replaced with the other vendor in V8.
