Newbie alert!
sdhastings
Wed Sep 24, 2014 3:52 pm
I keep a Hyper-V lab running on my Windows 8.1 system. I need to create a cluster (Symantec SFHA) and I need to share disks between 2 or more VM's.
Can someone provide some guidance? Can I just create a drive and attach it to 2 machines, or do I need a virtual SAN switch?
Any help is deeply appreciated
Mon Sep 29, 2014 8:48 pm
1. StarWind runs on top of the Windows Server starting from 2008 R2
2. I`m not sure why do you need Symantec SFHA if you are planning to create the shared storage using StarWind, so I~d appreciate if you could clarify that.
3. Since you are running on the Hyper-Vs, I think this guide will fit you well: http://www.starwindsoftware.com/styles- ... manual.pdf
Let me know if that helped please
harrydvdsn
Sat Oct 04, 2014 9:42 am
Anatoly (staff) wrote:1. StarWind runs on top of the Windows Server starting from 2008 R2
3. Since you are running on the Hyper-Vs, I think this guide will fit you well, which you can read to get more info, information and if it makes a difference, let me know. It could be an accident that they are not paying attention to it, if it is an accident, then you have my apologies because it was not before. more info below.
Well I'm on Hyper-vs so that link you provided was very helpful. Thanks. I'm also a new member to the forum.
Mon Oct 06, 2014 9:56 pm
Thank for the heads up!
