Crash during Hyper-V Storage Migration
jariangibson
Wed Oct 22, 2014 4:31 pm
Have a setup with 2 nodes of latest V8 build. During storage migration of VMs from local storage to shared storage over SMB to failover cluster backed by StarWind, both nodes lose connection and service hangs during restart.
iSCSI/Mirror/Synchronization over 10Gbe
Synchronization/SMB over 10Gbe - also Synchronization
Management 1Gbe for heartbeat
StarWind V8 on Windows Server 2012 R2 with SoFS clustering
MPIO setup
iSCSI points to local, then iSCSI, and then SMB for failover only
SMB traffic from Hyper-V restricted to Sync/SMB 10Gbe
Logs/dumps can be downloaded from here [ ... ]
Sat Oct 25, 2014 11:57 pm
Hi!
Sorry to hear that you are in trouble.
May I ask you to clarify what exactly have you tried to restart?
So, you are running iSCSI initiator and synchronization traffics on the same links? If so, then you should know that this is bad idea.
There is nothing there.
jariangibson
Tue Oct 28, 2014 2:14 pm
Even with 2 different 10Gbe nics?
I will re-upload the file and post link unless you have a better place to upload.
The service I restart is the StatWind Virtual SAN for vSphere.
Thu Oct 30, 2014 12:14 pm
Yes. SyncChannel is really important, so you should keep it separated from other traffic.
Well, you can try dropbox, box, gDrive, etc.
So, just to confirm, the client machine is loosing the connection to all StarWind targets after you are restarting the service on one of the node?
