activate synchronisation after an HDD crash in the first node
leon3147
Fri Aug 21, 2015 6:58 am
i have 2 nodes hyperv with StarWind on each nodes in HA.
HDD in the first node has crash, i change with a new one and a re create ntfs volume on it with the same letter as before.
The second node StarWind has all the device in synchronisation status = synchronized, but it say "Partner node is not ready".
So the replication don't start and i can't copy back the data from second node to first node !
In the first node stranges files appear. in example : "? imagefile1 (not active) "
How can i set the replication on ?
Is there a white paper or a technical documentation for change an HDD in the first node after a crash and reactivate the synchronisation to recover data in the first node ?
darklight
Tue Aug 25, 2015 9:07 am
Hi Leon,
Just remove the replica from the 1st node in Replication Manager, and remove all the faulty devices. Then recreate your HA device again from scratch. This will do the thing.
leon3147
Mon Aug 31, 2015 7:29 am
thanks for your help all is ok now.
Tarass (Staff)
Mon Aug 31, 2015 10:00 am
Any other questions on that case?
