For example, I have a Role, let's call it Server1. Server1 has a preferred owner of Node1, then Node2. Storage for Server1 is on CSV1, which is in Starwind and synchronised between Node1 and Node2. There's also a CSV2 - Roles with their storage on CSV1 failed, Roles with storage on CSV2 didn't.
I had assumed that if a Role is moved from Node1 to Node2 then I can safely restart Node1, as storage requests for Server1 will be handled by the copy of the CSV it uses for storage on Node2.
Am I doing it wrong? How can I tell? I spent a long time on the plan before I set it all up, I'm pretty sure it's right and normally I can install updates, failover a node, restart it and fail it back without problems. Repeatedly restarting a node seems to have upset the system somehow and I'd like to understand why.
I can imagine you might need more information, let me know. I think once I get what happened I'll have learnt something important...
